I recently purchased a 527w and need advise for setting up my existing VoIP service.
The Following are the only details I have previously used with other makes of router but I cant get the CISCO to register with the service so I guess I'm not completing the correct cells in the web interface.
I have 2 numbers with details as follows
Line Number | 1 |
MyNetFone Number | 091794** |
MyNetFone Password | $$$$$$$$ |
SIP Proxy | sip00.mynetfone.com.au |
SIP Port | 5060 |
Voice Codec | G.729, 40ms packet size |
Subscription Id | @@@@@@ |
Service Plan |
Line Number | 2 |
SIP Proxy | sip01.mynetfone.com.au |
SIP Port | 5061 |
Subscription Id | ###### |
Service Plan |
Obviously I have @@$$ my password and subscription details, so which cells do I put the above info into? I tried this and several other combinations (again the below id the actual info I put in the cells)
I tried what I thought were the correct ones as follows
Help would be appreciated Rob |
