Resolution
The power options for the Cisco Aironet 1500 Series are:
- AIR-PWR-ST-LT-TAP= If the access point is installed on a pole top, a streetlight power tap is available from Cisco. The streetlight power tap supports 105 to 260 VAC.
- AIR-PWRINJ1500=, AIR-ETH1500-150= If the access point is installed on a rooftop and is connected to the network, a power injector is available. Use the power injector with the outdoor-rated Ethernet cable for the Cisco Aironet 1500 Series. Do not use a power injector other than the AIR-PWRINJ1500=. The Cisco Aironet 1500 Series is not compliant with 802.3af and does not work with other power injectors.
- AIR-CORD1500-15NA= This is a 15-foot power cord, with a three-pronged North American plug at the end of it. It can be used for a lab environment, for a rooftop installation or a pole top installation. For rooftop installations, if the Cisco Aironet 1500 Series is connected to the network, you still need to use the Ethernet cable (AIR-ETH1500-150=). The power cord provides an alternative to the use of a power injector. Note that this part is orderable in the second quarter of 2006.
- AIR-CORD1500-40NA= This is a 40-foot power cord, with a three-pronged North American plug at the end of it. It can be used for a lab environment, for a rooftop installation or a pole top installation. For rooftop installations, if the Cisco Aironet 1500 Series is connected to the network, you still need to use the Ethernet cable (AIR-ETH1500-150=). The power cord provides an alternative to the use of a power injector. Note that this part is orderable in the second quarter of 2006.
- AIR-CORD1500-40UE= This is a 40-foot power cord, with an unterminated end. It is a three-wire cable that follows the European harmonization requirements. For customers in Denmark and Switzerland, you must configure a plug to your power cord. For all other countries, it is possible that you need to supply a country-specific plug. This cord can be used for a lab environment, for a rooftop installation, or a pole top installation. For rooftop installations, if the Cisco Aironet 1500 Series is connected to the network, you still need to use the Ethernet cable (AIR-ETH1500-150=). The power cord provides an alternative to the use of a power injector. Note that this part is orderable in the second quarter of 2006.
Refer to these documents for more information:
Problem Type
Power / cable compliance
Products
Access point
Mesh Access Point 1500
