chanchan1029
wlc 5508 flexconnect vm bridge use Issues
The current configuration
Problem
flexconnect wireless LAN users (VM: WINXP) bridge mode using dhcp ip will not be granted.
Environment
model:5508
version:7.4.110.0
user pc
LOCAL OS : WINDOWS7
VM OS:WINDOWS XP
VM: OVM ( Oracle)
Current Action
WLC Configuration
config dhcp proxy disable
config dhcp proxy disable bootp-broadcast enable config dhcp proxy disable
after the results are the same
If you use an existing version 7.0.240.0 Service Success
Thank you
