Are you wired for Wi-Fi 6? You’re up against big network demands. Hear industry experts and influencers discuss cutting-edge wired and wireless solutions.
Post your questions below in the comments section.
Will the new WiFi6 APs have wider area coverage? I understand there will be higher bandwidth and lower latency, and higher device capacity as well as lower device power requirements. What we want to know is, based on the coverage, if we are planning on using AIR-AP3802I-E devices, will we require the same or less WiFi6 devices?
Coverage is going to be similar, but quality of connection is going to improve.
