how to connect iPhone to WPA2 enabled enviroment where as user database is integrated with AD ( ssid is not broadcasted )
vinodjad1234
Level 2
Level 2
I have couple of users to whom , i am trying to connect to my wireless LAN set-up
1) My SSID is not broadcasted
2) WPA2 enabled SSID
3) User database is integrated with AD
how should i go ahead and configure iPhone as if it is part of our network and connected to wireless network ....
I am unable to get documents of that....
vinodjad1234
Level 2
Level 2
Main challenge is to integrate to AD ... how do i do that ?
Scott Fella
Do you have a working wireless solution now using WPA2? The reason I ask is that if you have one working with AD, you are probably doing 802.1x. Something like PEAP MSCHAPv2. This also requires a radius server like Microsoft IAS or NPS. Just google WLC PEAP using IAS and you will find a lot of documents that might help.
Once you get that setup, you just manually setup the iPhone or WPA2 Enterprise and enter the AD login.
-Scott
