lap1262n lap to autonomous
Driss Hadi
                   Hello Colleagues
Please there is any way to change the OS from LAP to Autonomous for  lap1262n
18 Replies 18
Change your subnet mask on your PC to 255.255.255.0 and no need for a default gateway.  Disable any firewall on your machine and then follow the previous instructions.  You don't need to change the ip address on the AP and now you willo need to erase and reboot.  So when you are in the CLI of the AP, issue a write erase and then reboot without saving.  When the ap comes back, make sure there is no static address set.  Then follow the proceedures above.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Emmanuel Valdez
Level 3
Level 3
Hello Driss,
This topic is a little confusing, I did the conversion many time ago and for not confusing you I recommed you to watch this youtube videos:
http://www.youtube.com/watch?v=wWDrFjwVNb0
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
If it is useful please rate.
Best regards.
Hello
i was going via all the tools provided by our cloeagues and your tools as well but the main problem i cannot reach the interface of access point is something strange i never got is in my life
now the access hunging on the :
not sending discover request ap doesn't have an ip ..
thank you
Hello Team ,
Thanks a lot for the support
when i investigate it''s firewall behind blocking the transfer of the ios / actually the Chinese youtoob solution was help full a lot
see you in the coming scenario
Driss
