syslog logging from autonomous client ap to lwapp root
pavel.mr4
Hi everyone!
We have some 1532 autonomous ap as clients asociated to lwapp roots in a WGB enviroment. I need to save the logs from the wgb clients (autonomous ap) so I can troubleshoot an issue. I tried setting a syslog server on the wgb client with the following commands:
logging history size 500
logging history informational
logging host 10.190.73.166
The thing is that I can ping the syslog address, but the syslog server has no events or registry at all (the syslog server does not get any log from the ap).
could this be a capwap issue or something ?
BR!
Hi Rasika,
Thank you for your quick response, but i tried this syslog server in a few other aps with autonomous wgb's and occurs the same, so i started thinking it might be some server security issue. anyways, let me get the output and attach it.
BR!
Rasika Nayanajith
Try below & see if that helps
logging buffered 100000 informational
Post "show logging" output from your WGB
Rasika
Hi Rasika,
BR!
