12-02-2012 08:45 AM - edited 07-03-2021 11:09 PM
We have a setup as 1 SSID in air , authentication via LDAP
One user login as aaa to VLAN 51
other user login as bbb to VLAN 52
I want to setup different rate limiters for those users.As i know thera are 2 methods of rate limiting available in WLC
a)per User in the same SSID
b)per SSID for any user
In this case there is only one WLAN so we cant use b , as i dont want all users to get same bandwidth contract rate limiting method a isnt useful for us.Because i want to seperate employee / guest / admin bandwidth limits.
How can i overcome of this case ?
12-02-2012 08:51 AM
With one WLAN you are limited to what the WLC can do. The rate limiting as you already know only works with the WLAN in question and defines the rate limiting for that WLAN. The WLC doesn't rate limit on an interface which would helps you in this case. What you will need to look at is if you can rate limit on the network switch. This way you can try to limit the traffic from the vlan and not really care about the WLAN.
12-02-2012 09:00 AM
Can we do this via ACL s ?
and one more question , is there any chance to do a dynamic WLAN assignment ?
12-02-2012 09:03 AM
I think you can do some rate limiting on the layer 3 interface, but maybe depends on your equipment.
12-02-2012 09:04 AM
What do you mean by dynamic WLAN assignment?
12-02-2012 09:19 AM
For the first question ;
What do you mean with "maybe depends on your equipment" ?
For the second question ;
Sorry it has to be "VLAN" assignment , and i have found the solution.
As i read
Three types of attribute has to be returned from ldap server.All three of these has to be returned or just Private group id is enough ?
12-02-2012 10:02 AM
It depends on your equipment if you can configure certain vlan rate limits.... Okay.,... dynamic vlans is more like it.... yes it is possible using IETF if your using no cisco radius. Cisco radius you can just set the vlan id in the end station filter. I set all 3 when using MS radius.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
12-02-2012 10:04 AM
Here is another link:
https://supportforums.cisco.com/thread/1002299
Scott
12-02-2012 10:07 AM
Here is a great example if your using MS radius:
Scott
