AP541 Clustering
mksolutions
Hello.
I have 3 AP541N. I become this not in a cluster. The APs standalone in the room. The first AP connect with cable to a DHCP Router from a other manufacturer. The other both APs should be connect over WLAN.
How I must configure the APs? Which parameters must install?
I doesn't found any guide for this.
divg
HI Michael,
I am Divakar from Cisco Small Business Support Center.
I think the below link where you can download the Administration guides for AP541 can help you out in clustering your device.
http://www.cisco.com/en/US/products/ps10492/prod_maintenance_guides_list.html
If you still have queries then you can reply to this discussion.
Thanks and regards.
