AP541N v1.7.0(2)& Dell Wireless Utility
Chromium08
Premier Partner set-up new AP541N's and we're having difficulty connecting with WPA2 with our Dell Latitude E4300s using the Dell Wireless Utility.  Our Latitude D600/630's successfully connect with WPA2 via WZC.
The E4300 start @ IP127.x.x.x, run 'acquiring network address', then show connected to IP 169.x.x.x.  The D600/D630's start @ IP127.x.x.x, run 'acquiring network address', then show  connected to IP 192.x.x.x and users successfully connect to the LAN and internet.
Anyone else having issues with AP541N's v1.7.0(2) and Dell wireless utility?
Chromium08
Update.  Dell Latitudes successfully connect with security set to 'None'.  Set security to 'WPA Personal' with only WPA checked ( WPA2 not checked ) and users were prompted for password, user enters the password and connects.  The following day, same security settings with new password and both previous day's users and new users are not prompted for a password and are unable to connect.  Set security to 'None' and all users connect.
Suggestions?
