CBW150AX-B stuck on Green Blinking
Chuck6880
I have 2 cisco CBW150ax-B access points, that are Stuck in blinking green, both were working part of a 7 group of all CBW150ax's with a CBS250 POE switch,  I have done the factory reset on then both, but they just continue to blink Green, off then green,  I tried the resets multiple times, Right now I have them connected to the power injectors.
Any Suggestions?
and how to get warranty support? when I look up the number it says it doesn't exist
0 Replies 0
