Cisco WAP 551 Guest issues
JoseOlivas
After setting up a wap551 AP I had to set the guest VLAN ID to 1 which is on the same VLAN as my corporate users. If it is not on VLAN 1 hen it gets no internet access. Any help on is would be appreciated. I did see a post about the WAP321 with the fix being to make the VLAN 2 the managed VLAN.  Not a secure fix in my opinion.
In addition, when connecting to the guest ssid they are taken to a cisco authentication page.  My client would like them to bypass any pages as they would only have access if we provide it.
Jose
Eric Moyers
Level 7
Level 7
I saw your post on the WAP321 thread.
I agree it is not the best solution, It can be used as a workaround. Listed below are the recommendations to security concerns.
1) Problem: If a wireless client knows the IP of the WAP and the username and password they could get into the WAP.
Solution: Setup Management Access Control to an IP outside the DHCP scope for that VLAN and have a Strong Password.
2) Problem: Management of the WAP321 can only be from an IP on the Management VLAN. (In my case 2)
About the authentication page: If Captive Portal (CP) is not enable this should not be happening. Did you use Captive Portal? With CP the minimum that can be enabled is a authentication page where the guest would have to use a name but no password.
But as long as CP is not enable they should be able to get directly out to Internet once the connect to the SSID.
Eric Moyers    .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
Wireless Subject Matter Expert
CCNA, CCNA-Wireless
Thanks for your reply.  I am not sure if the CP is enabled or not, as I reset the system three times fighting with the guest access issues.  I will take a look at the system as soon as I am able, since it is in a remote location it will take me a bit to get access.
