CISCO WAP4410N/CISCO AP 541N
saroj pradhan
Can  any one help me  if  we compare the 2 AP  Which one is better  .
if we not consider the cluster function of ap541n.
i got some info from blog the device  wap 4410n  got hanged .
Saroj
HI Saroj,
     Both are Dual Band Accesspoints.But In WAP4410N IEEE802.11a Wireless Standars do not support.Ap541N do Supports IEE802.11a Datalink Protocol.And Both  do support all Remaining Datalink Protocols Such as IEEE802.11g,b,n.Both will give 300Mbps Throughput.
  And Some Encryption Algorithms Also Different from both of this.
AP541N Encryption Algorithm.
64-bit WEP, WPA-PSK, 128-bit AES, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
WAP4410N  Encryption Algorithm.
128-bit WEP, 64-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
  Prakash@CIL.
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
Actually the WAP4410N is only a single band radio access point. It can only broadcast a 2.4 GHz signal in B, G,and N. The AP541N is a dual band radio access point. It can broadcast its signal in 2.4 GHz in B,G,N or 5.0 GHz, in the A,  N range.  But it can only broadcast in 2.4 or 5.0 it can not do both at the same time.
I have attached a brochure that details the diffewrence between the different AP's that we have.
Please let me know if you have any other questions.
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
HI Eric Moyers,
I have seen iN Some Cisco Datasheets,and i Came to know that these Accesspoints Operate in Both BAnds.But as per your documentation wap4410 N Operates in Singal Band such as 2.4 GHZ, but which i followed the datasheet, in that These Accesspoints operate in Both The Frequency Bands. Culd you please remove this Confusion.
Below is red marked for your reference.
http://www.cisco.com/en/US/products/ps10047/prod_models_comparison.html.
RAM Installed ( Max )64 MBN/A
Flash Memory Installed (Max)32 MBN/A
Hard DriveNone.None.
Networking
Form FactorExternalExternal
Connectivity TechnologyWirelessWireless
Data Transfer Rate300 Mbps300 Mbps
Data Link ProtocolIEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Spread Spectrum MethodOFDM, DSSSOFDM, DSSS
Remote Management ProtocolSNMP 1, SNMP 2, SNMP 3SNMP 1, SNMP 2c, HTTP, HTTPS
Frequency Band2.4 GHz, 5 GHz2.4 GHz, 5 GHz
Status IndicatorsPort status, port transmission speed, powerLink activity, power, link OK
FeaturesDHCP support, load balancing, VLAN support, Syslog support, firmware upgradable, MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), wireless bridge mode, clustering technologyDHCP support, power over Ethernet (PoE), load balancing, VLAN support, Syslog support, E-mail alert, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, firmware upgradable, MIMO technology, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), wireless bridge mode
Encryption Algorithm64-bit WEP, WPA-PSK, 128-bit AES, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise128-bit WEP, 64-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication MethodRADIUS, Basic Service Set Identifier (BSSID)RADIUS, Radio Service Set ID (SSID), Basic Service Set Identifier (BSSID)
Compliant StandardsIEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n (draft), Wi-Fi Protected Setup
Line Coding FormatN/AOFDM
Network / Transport ProtocolN/ADHCP
Antenna
AntennaExternal detachableExternal detachable
Antenna Qty33
DirectivityOmni-directionalOmni-directional
Gain Level2 dBi2 dBi
Expansion / Connectivity
Interfaces1 x network / power - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-451 x network / power - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
Miscellaneous
Cables Included1 x network cable1 x network cable
Compliant StandardsCE, EN 300.328, EN 301.489.1, EN 301.489.17, RSS-210, IC, ICES-003 Class A, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, EN 301.893CE, IC, FCC
Power
Power Over Ethernet (PoE) SupportedYesYes
Power DevicePower adapter - externalPower adapter - external
Voltage RequiredAC 120/230 V ( 50/60 Hz )N/A
Software / System Requirements
OS ProvidedLinuxLinux
Manufacturer Warranty
Service & SupportLimited lifetime warranty3 years warranty
Service & Support DetailsLimited warranty - replacement - lifetimeLimited warranty - replacement - 3 years,
New releases update - 90 days,
Technical support - phone consulting - 1 year
Environmental Parameters
Min Operating Temperature32 °F32 °F
Max Operating Temperature104 °F104 °F
Humidity Range Operating10 - 85%10 - 85%
Product ImageAP541NWAP4410N
Prakash@CIL.
Thank you for pointing that out to me. I will notify the appropriate people to have it modified.
Eric Moyers
