Cisco Wireless - Client DeAuthentication issue. Unspecified ReasonCode1
SOcchiogrosso
Level 4
Level 4
I have a WLC 2125 with 1252 LWAPPs.
In the recent traps of the WLC I get loads of DeAuth messages. If I do not clear the traps it can exceed a few hundred entries after a couple hour period.
I can not find anything on Reason Code1
Example Error:
Client Deauthenticated: MACAddress: MAC ADDRESS Base Radio  MAC: MAC ADDRESS Slot: 0 User Name: unknown Ip Address: IP Address  Reason:Unspecified ReasonCode: 1
Any common issue/resolution with this I can not seem to find?
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
trimmy
I have the same issue? any luck getting this resolved- we have 802.1x backend auth. The user successfully authenticates, but then is deauthenticated as in your message. I thought there might be a DHCP issue but the server is working for other scopes.
I believe my issue was caused by MFP, Management Frame Protection, most of my clients were not CCXv5 compliant at the time.
I disabled MFP on the controller, AP's, and WLAN..
has prolem solved??
