Configure RV110W as a CLIENT WIFI
didierbodinier
Hello everybody
I 've just bought RV110W to add a wifi Junction to my ethernet printer . I have a Cisco Aeronet access point (Wifi) as a wifi acces to my LAN.
Here are my parameters
Main wifi :Cisco Aeronet access point
SSID Mylan
WEP 128 BITS
IP 15.12.30.10
mask 255.25.255.0
Gateway 15.10.30.254
Now I'd like to connect my RV110W to that Box ....  and i haven't successed to parameter wifi connection
I have enter in LAN 15.12.30.14/255.255.255.0  and i can ping through lan my RV110W
I have entered same SSID whith same wep key (Security ) but may main wifi box desn't "see" my secondary wifi gateway (my RV110W)
I have two differents chanels
So i'd be very happy if any body can confirm that i can set this wifi connection  and secundary i Like to get explanation on the good configuration for my RV110W.
Thank you
0 Replies 0
