How to fix cisco wrvs4400n2 that always reboot
cablakcokrem
I had been using wireless router cisco wrvs4400n2 for almost 4 months, and it's really running perfectly.
Not much changing in configuration, WAN IP = DHCP, and on LAN I'm using DHCP server, Firewall and IPS are enabled by default.
But now it almost 1 months the router keep getting reboot after 2 days running normally after that 2 days needs reboot and it continues until now.
Please give me solution for fixing my router so I don't need to reboot it as always
Rgds,
Hamzah
Eric Moyers
Level 7
Level 7
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
What firmware are you currently running? Also Was anything new added to the network or removed?
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
The router use firmware V2.0.2.1, and nothing new added or removed for the router.
