No login screen for WAP371
Scott216
I have two WAP371 access points.  Each is on it's own VLAN plugged into a cisco RV320 router.  I can join the wifi network on each WAP.  I'm trying to log into the WAP to configure it.  I know the IPs for the WAPs and I double checked by looking at the default gateway using ipconfg from command window.   In my browser when I go to the WAP's IP, I don't get a login screen.  It says the site can't be reached.  I'm using Chrome browser on Windows 10.  From the command screen I can ping the WAP and it responds.  I have the same issue with both WAPs.  BTW - these WAP access points were not setup by me.  I'm helping a friend.  I have the username and password, but I just can't get a login screen.  I don't want to factory reset them.
0 Replies 0
