Small Biz Wireless
grahamhand
Hi members, I have a customer who owns a Pub and wants to setup wireless access for its guests.
I have ordered a seprate internet connection and wanted some advice on a solution.
The site is quite large but typically each area is isolated from the next.
There will be a big back area which will have some overlapping AP's
I intend to have around 4 AP's indoors and at least 2 AP's outdoors.
I have cabled some Cat 6a cables to each location.
I intend to run the AP's off a POE switch.
I was thinking of putting in 4 x WAP121 or 4 x WAP4410N. I also looked at the Cisco 500 but the page wouldnt load.
For the Outdoor I am not sure which way to go.
Do these AP's require a controller?
Is it possible to avoid overlapping signals as well without a controller?
I am not really looking for total coverage and avoiding dead spots, more so just providing free internet in key areas like dining and bar etc.
Looking forward to some advice.
Thanks in advance.
Leo Laohoo
What do you mean by "isolated"?  Describe the walls?  The heights of the ceiling?  The height where you plan to install the AP?  How do you plan to install the AP?  Too much info is WAY BETTER than no info.
The best way is with a controller because not only does the radio interferrence get monitored and change automatically but you configure all your APs ONCE, on the controller.  Your APs will become a true plug-and-play.
You have but three choices:
1.  You can stick with SMB.  You need to configure each and one of them.  It's cheap.
2.  Cisco recently bought out Meraki.  It's cheaper than the Cisco enterprise grade and Meraki's got PoE switches, wireless controllers and AP.
3.   Cisco Aironet products.  Big-daddy of them all.  Cisco CleanAir and operating in a bar with lots of potential wireless interferrance ... it's the best thing that you can have right now.
You can get the refurbished Cisco Aironet and PoE switches from Cisco Refurbished Equipment for less but you also get the warranty and/or Service Contract.
Cisco's APs now have Cisco Limited Lifetime Warranty so you don't need to purchase maintenance.  If you want to purchase a Wireless LAN Controller, purchase the maintenance and service contract for the WLC so you can download the firmware.  For switches, some Cisco Catalyst (enterprise) switches now come with Enhanced Limited Lifetime Warranty (next day replacement vs 10 business days replacement).
Hi Leo, thanks for the response.
What I mean by isolated is that each Radios position is out of radio range of an adjacent AP.
With the Meraki do you pay for a cloud license?
jkilleda
Level 3
Level 3
Hi Graham,
Small Biz Wireless
You need to convert the AP's to autonomous in order to connect them without a controller.
