WAP 200 is slow
aonetelecom
Hi team
We have 3 WAP 200 installed at our office, and i was checking the speed yesterday i been to www.speedtest.net, and we have cable modem, the speed i was getting 25.0 Mbps down and 2.0 Mbps UP when i was connected via a wire, but if i am connected via wireless the speed i was getting 12.0 Mbps Down it is almost half, MY laptop have G wireless client, and i was very close to access point, my signal strength was Excellent, Any body have any idea how can improve that, i checked with 3 different laptops i was getting the same results, All three access points are connected directly to POE switch, when i was connected through wire i was connected to same switch. All three access points are configured individually,
Any help will be really appriciated
jasbryan
Level 6
Level 6
Krishan,
Yes, Wireless is half duplex so your laptop and AP only transmits and receives at one given time. you're speed will be cut in half.
Jasbryan
jasbryan
Level 6
Level 6
Krishan,
Jasbryan
Thanks Alot i was forget
