12-10-2018 03:34 AM - edited 12-12-2018 12:14 AM
we have WAP150 Access Points, to separate traffic we want to use additional WLAN id with separate VLAN.
The AP is configured, WLAN1 with VLAN1 works, devices on WLAN2 with VLAN2 get IP Adress but cannot ping or open internet websites. Have tested two switches with the same result (Dlink DGS-1510, HP ProCurve 1810G) connected to a Fritz!Box Router with guest network. The two router Ports LAN and GUEST are connected with Untagged Port in VLAN 1 and 2. The WAP is connected to a Port with VLAN1 untagged and VLAN2 tagged (Dlink = Hybrid VLAN, have also tested as Trunk Port). When Pinging form a WLAN2 windows notebook wireshark shows no ICMP traffic from the WAP150 to the Fritz!Box, but wireshark on the notebook shows unanswered ICMP traffic.
What is going wrong? Thanks in advance, best regards.
12-12-2018 12:13 AM
12-12-2018 05:24 AM
