04-29-2014 01:31 PM
06-17-2014 12:51 PM
Captive Portal does work on other VLAN's. You need to configure inter-vlan routing as appropriate and set up all aspects of CP including Web Portal Customization.
01-21-2015 06:10 AM
Please refer to the following link, and check if that helps.
https://supportforums.cisco.com/discussion/11992766/wap321-captive-portal-2-different-vlan
