WAP321 - How can I distribute bandwidth to different SSIDs?
jackyamsc
I just purchased the WAP321 and am overwhelmed by the amount of controls in the admin interface.
I had a WAP4410N (which I returned to Cisco), which had the option of allowing me to distribute my bandwidth to different SSIDs on the same access point.
I am not able to find the options in the WAP321. Has anyone done this yet and could you please share how you went about it?
Thanks!
Jack
Singapore
David Hornstein
Level 7
Level 7
Hi Jack,
This WAP seems to extend the options available to you compared to the older WAP4410N.
You can add people to different SSID if you want.  You then have to option to limit the virtual AP, check out the screen capture below;
You can see that I circled the help option, select this option if you want to understand this page in greater detail.
regards Dave
David Hornstein
Level 7
Level 7
Hi Jack,
regards Dave
Hi David,
Thanks for the information. Will go check on this page.
Much appreciated.
Cheers,
Jack
Hi David,
I must be blind. It was just there, but I did not see it! Thank you for pointing me in the right direction!
Cheers,
Jack
