Access Points connection drop approximately 30 times with 802.1x Radius
Ekin Gumus
Hello Everyone,
As you can see from the top this is my problem that could not solve for 2 weeks. To summarize again, I used to my access points with standart configuration, I mean vlans, dhcp and other basic configration. After we increased security of our access points we started to encouter connection drops issue.
These are the example logs;
Interface Dot11Radio0, Deauthenticating Station xxxx.xxxx.xxxx (my mac address) Reason: Previous authentication no longer valid
Also a lot of:
interface Dot11Radio0, Deauthenticating Station xxxx.xxxx.xxxx (my mac address) Reason: Sending station has left the BSS
as well as we have a lot of authentication failures such like:
%DOT11-7-AUTH_FAILED: Station xxxx.xxxx.xxxx (my mac address) Authentication failed
What should I do ?
Thanks in advance
0 Replies 0
