10-09-2017 10:04 PM - edited 03-21-2019 10:48 AM
Scheduler is not operational for VAP 0. There is no possibility of selecting the Profile Name.
I have already done a factory reset without result.
I put the latest firmware version.
the error is present on Radio 1 and 2 only on VAP 0
10-15-2017 05:10 PM
Hello aprelaz@outlook.com
Is the Administrative Mode is enabled ?
-If I helped you somehow, please, rate it as useful.-
10-15-2017 09:27 PM
Yes the Administrative Mode is enabled.
I did several tests but could not put a scheduler on the first network VAP 0
I wonder if the firmware does not have a bug ?
Help
10-15-2017 09:35 PM
Probably yes. Can you try a different versions?
10-16-2017 02:43 AM
I'm currently on Firmware Version (Active Image): 1.3.0.4
I will test with different versions.
I'll keep you informed.
Thank you
10-16-2017 10:55 AM
I have tested with version 1.3.0.4 - 1.2.1.3 - 1.1.2.3 - 1.0.1.5
all give the same result.
HELP
