WAP4410N-G5 firmware version 2.0.4.2
ANDREY VORONOV
I received WAP4410N-G5 AP with 2.0.2.1 firmware and set up it very easily. Never experienced a single signal drop in a few days.
After updating firmware to 2.0.4.2 version I am completly unable to make any changes! If I press on "Enable" or "Disable" all settings will be lost after I apply them and neither "Enabled" nor "Disabled" is selected.
Had to revert back to 2.0.2.1. Is my AP faulty?
Eric Moyers
Level 7
Level 7
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
At this point I do not think your device is faulty. What browser are you using when making your changes?
Eric Moyers
Cisco Network Support Engineer
CCNA, CCNA-Wireless
1-866-606-1866
Tried both IE and latest chrome. Resetting to factory defaults before upgrading didn't help either.
I attached screenshot if i select something and press "save" nothing is saved and selection disappear.
Date: Tue, 11 Oct 2011 11:24:56 -0600
To: a.voronov@hotmail.co.uk
Subject: - Re: WAP4410N-G5 firmware version 2.0.4.2
Re: WAP4410N-G5 firmware version 2.0.4.2 created by Eric Moyers in Small Business Wireless - View the full discussion
Eric Moyers
CCNA, CCNA-Wireless
1-866-606-1866
Reply to this message by going to Cisco Support Community
Start a new discussion in Small Business Wireless at Cisco Support Community
Not sure about the latest Chrome, But I know that I have used IE 8 with no issues. I have heard that IE 9 has had issues with some of our other GUIs, so I would not use that. I also know that Firefox 3.5.1 works as well.
Eric
Installed Fireworks 7.0.1. config works!
Maximum speed still limited to 130Mb.
Date: Tue, 11 Oct 2011 13:05:19 -0600
Not sure about the latest Chrome, But I know that I have used IE 8 with no issues. I have heard that IE 9 has had issues with some of our other GUIs, so I would not use that. I also know theat Firefox 3.5.1 works as well.
Eric
