02-08-2012 08:46 AM
My network management platform flags the WAP4410N as continuously reporting 100% memory utilization. I updated to the latest code(V2.0.4.2, but the problem persists. I confirmed with the software vendor that the MIB is actually reporting 100% utilization. Has anyone else seen this symptom?
02-17-2012 11:35 AM
We have three of these and Solar Winds is reporting 100% utilization. I updated the firmware on one to 2.0.4.2 but they are still reporting at 100%
02-20-2012 07:31 AM
Paul,
I haven't seen any case within the support center reporting high memory utilization consistently. If you are experiencing problems with 4410 then i would give the SBSC @ 1-866-606-1866 a call. If no problem persist then it's probably just a spike at which time all units will generally spike occasionally at 100%
Jasbryan
06-05-2013 02:51 PM
I am having the same problem with SolarWinds reporting 100% memory utilization, 100% CPU utilization and also reports several reboots per day, however, the GUI shows the uptime as several days. I upgraded firmware to latest 2.0.6.1 and nothing has changed.
Has anyone found a fix for this since the last post?
11-06-2014 11:07 PM
Hello. Is there anyone have this solution ? because im also face this problem. Have 4 pcs of this wifi and my HP IMC display that wifi memory full to 100%.
Any solution from HP?
