WAP4410N v2 stops responding
pschotte77
  I recently installed six of the WAP4410N v2 models, firmware 2.0.4.2 all facing the same issue as described in this post.  Is Cisco still working on this issue?  Any progress or plans to come to a solution in the nearby future?
rroy
As per my observation this device is having prblem when we use mix mode (B/G/N) and the clients are also
mixed, like some clients are using old laptops which supports 802.11B, Some laptops are 802.11G and the new laptop
users are using 802.11N mode.
At the time of problem, only 802.11N clients (laptops) are disconnected, remaining old laptops which are using
802.11B & G mode are working as usual.
I have also tested the latest firmware 2.0.5.3 on this AP but no result. Still same issue.
Now waiting for Cisco Support to come back with some proper solution.
  In Wireless Channel, kindly change the channel to 40MHZ & check, i don't think so upgrading of Firmware will change.
regards
Xavier
