WLC 2500 SOCKET_TASK-7-DATA_PROCESSING_FAILED
Marcus Fuchs
Hello all,
Hallo all,
following situation
WLC 2500 working only for OfficeExtend with Aironet 600 Series.
SW: 8.0.120
In the log I receive the lot of this massages.
ipv6SocketTask: Oct 01 09:11:02.564: #SOCKET_TASK-7-DATA_PROCESSING_FAILED: socket_task.c:193 Failed to process 170 bytes on protocol socket 18
*ipv6SocketTask: Oct 01 09:10:59.777: #SOCKET_TASK-7-DATA_PROCESSING_FAILED: socket_task.c:193 Failed to process 170 bytes on protocol socket 18
*ipv6SocketTask: Oct 01 09:10:54.560: #SOCKET_TASK-7-DATA_PROCESSING_FAILED: socket_task.c:193 Failed to process 170 bytes on protocol socket 18
*ipv6SocketTask: Oct 01 09:10:52.780: #SOCKET_TASK-7-DATA_PROCESSING_FAILED: socket_task.c:193 Failed to process 170 bytes on protocol socket 18
*ipv6SocketTask: Oct 01 09:10:52.379: #SOCKET_TASK-7-DATA_PROCESSING_FAILED: socket_task.c:193 Failed to process 167 bytes on protocol socket 18
*ipv6SocketTask: Oct 01 09:10:50.553: #SOCKET_TASK-7-DATA_PROCESSING_FAILED: socket_task.c:193 Failed to process 170 bytes on protocol socket 18[...It occurred 2 times/sec!.]
*ipv6SocketTask: Oct 01 09:10:47.545: #SOCKET_TASK-7-DATA_PROCESSING_FAILED: socket_task.c:193 Failed to process 170 bytes on protocol socket 18
*ipv6SocketTask: Oct 01 09:10:44.778: #SOCKET_TASK-7-DATA_PROCESSING_FAILED: socket_task.c:193 Failed to process 170 bytes on protocol socket 18
*ipv6SocketTask: Oct 01 09:10:43.773: #SOCKET_TASK-7-DATA_PROCESSING_FAILED: socket_task.c:193 Failed to process 170 bytes on protocol socket 18
*ipv6SocketTask: Oct 01 09:10:40.769: #SOCKET_TASK-7-DATA_PROCESSING_FAILED: socket_task.c:193 Failed to process 170 bytes on protocol socket 18
I can’t found no statement for with massage.
Can someone help me?
What is the problem.
Greets Marcus
Catalin Sandu
Did you solved this issue ?
Catalin,
Hi Catalin,
under Controller --> "disable" Globale IPv6 Config.
greets Marcus
