WRVS4400N PPPoE connection problem
elviscendak
Hi All,
I have a problem connecting router to internet. I try to connect with other router Netgear WPN824, Linksys WRT54G, Allied Telesyn AT-AR220E and with this working without any problem.
I have static IP but I need PPPoE connection with username and password.
Router Cisco Linksys WRVS4400Nv2 with firmware 2.0.0.8-ETSI, CPU STAR 9202, DRAM 64MB, FLASH 16MB.
My connection is ADSL 10Mbps/768kbps and ISP (Slovenia - SiOL) need PPPoE connection.
Modem is Sagem Fast 3344, Bridged, DHCP disabled, Firewall Disabled, Ethernet Status Automatic Speed Auto DUPLEX.
Please help me with this router connection.
Thanks.
This is the LOG of the router:
Jan 1 00:00:07 - bind 0.0.0.0 - Address already in use
Jan 1 00:00:07 - started as root without requesting chroot(), warning only
Jan 1 00:00:07 - starting on , port 80
Jan 1 00:00:20 - Plugin pppoe loaded.
Jan 1 00:00:20 - PPPoE Plugin Initialized
Jan 1 00:00:20 - Plugin pppoe called.
Jan 1 00:00:21 - pppd 2.4.1 started by root, uid 0
Jan 1 00:00:21 - Sending PADI
Jan 1 00:00:21 - HOST_UNIQ successful match
Jan 1 00:00:21 - Unexpected packet: Ether addr: 00:19:4b:60:ab:4d (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0046 (PADO) PPPoE tag: type=0102 length=0014 (AC Name) data (UTF-8): E320-BRAS-LJ-DRAVLJE PPPoE tag: type=0103 length=0004 (Hos
Jan 1 00:00:21 - Unexpected packet: Ether addr: 00:19:4b:60:ab:4d (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0049 (PADO) PPPoE tag: type=0102 length=0017 (AC Name) data (UTF-8): E320-BRAS-LJ-CIGALETOVA PPPoE tag: type=0103 length=0004 (
Jan 1 00:00:21 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x427d8
Jan 1 00:00:21 - Couldn't get channel number: Transport endpoint is not connected
Jan 1 00:00:21 - Doing disconnect
Jan 1 00:00:21 - Exit.
Jan 1 00:00:21 - br0: port 2(eth2) entering forwarding state
Jan 1 00:00:21 - br0: topology change detected, propagating
Jan 1 00:00:21 - br0: port 1(eth0) entering forwarding state
Jan 1 00:00:27 - download uses obsolete (PF_INET,SOCK_PACKET)
Jan 1 00:00:28 - Kris Linux Driver:Version=v2.00 for CISCO's RVSR000,WRVS4400N & WRVS4400Nv2(Feb 18 2009:18:16:43)
Jan 1 00:00:28 - Enable Tcp Connection Tracking
Jan 1 00:00:28 - The Total Used Table Memory Size = 0xFB4878 = 16082K
Jan 1 00:00:28 - Trying to free free IRQ16
Jan 1 00:00:28 - Trying to free free IRQ17
Jan 1 00:00:29 - version 0.7.2 started
Jan 1 00:00:33 - Kris is unlocked
Jan 1 00:00:33 - Reset IDP Engine!!!
Jan 1 00:00:33 - The Total Used Table Memory Size = 0xFB4878 = 16082K
Jan 1 00:00:33 - Enable DDOS Detection!!
Jan 1 00:00:33 - Enable PortScan Detection!!
Jan 1 00:00:33 - Enable IP Sweep Detection!!
Jan 1 00:00:50 - Plugin pppoe loaded.
Jan 1 00:00:50 - PPPoE Plugin Initialized
Jan 1 00:00:50 - Plugin pppoe called.
Jan 1 00:00:50 - pppd 2.4.1 started by root, uid 0
Jan 1 00:00:50 - Sending PADI
Jan 1 00:00:50 - HOST_UNIQ successful match
Jan 1 00:00:50 - Unexpected packet: Ether addr: 00:19:4b:60:ab:4d (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0046 (PADO) PPPoE tag: type=0102 length=0014 (AC Name) data (UTF-8): E320-BRAS-LJ-DRAVLJE PPPoE tag: type=0103 length=0004 (Hos
Jan 1 00:00:50 - Unexpected packet: Ether addr: 00:19:4b:60:ab:4d (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0049 (PADO) PPPoE tag: type=0102 length=0017 (AC Name) data (UTF-8): E320-BRAS-LJ-CIGALETOVA PPPoE tag: type=0103 length=0004 (
Jan 1 00:00:50 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x427d8
Jan 1 00:00:50 - Couldn't get channel number: Transport endpoint is not connected
Jan 1 00:00:50 - Doing disconnect
Jan 1 00:00:50 - Exit.
Jan 1 00:01:20 - Plugin pppoe loaded.
Jan 1 00:01:20 - PPPoE Plugin Initialized
Jan 1 00:01:20 - Plugin pppoe called.
Jan 1 00:01:20 - pppd 2.4.1 started by root, uid 0
Jan 1 00:01:20 - Sending PADI
Jan 1 00:01:20 - HOST_UNIQ successful match
Jan 1 00:01:20 - Unexpected packet: Ether addr: 00:19:4b:60:ab:4d (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0046 (PADO) PPPoE tag: type=0102 length=0014 (AC Name) data (UTF-8): E320-BRAS-LJ-DRAVLJE PPPoE tag: type=0103 length=0004 (Hos
Jan 1 00:01:20 - Unexpected packet: Ether addr: 00:19:4b:60:ab:4d (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0049 (PADO) PPPoE tag: type=0102 length=0017 (AC Name) data (UTF-8): E320-BRAS-LJ-CIGALETOVA PPPoE tag: type=0103 length=0004 (
Jan 1 00:01:20 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x427d8
Jan 1 00:01:20 - Couldn't get channel number: Transport endpoint is not connected
Jan 1 00:01:20 - Doing disconnect
Jan 1 00:01:20 - Exit.
Jan 1 00:01:50 - Plugin pppoe loaded.
Jan 1 00:01:50 - PPPoE Plugin Initialized
Jan 1 00:01:50 - Plugin pppoe called.
Jan 1 00:01:50 - pppd 2.4.1 started by root, uid 0
Jan 1 00:01:50 - Sending PADI
Jan 1 00:01:50 - HOST_UNIQ successful match
Jan 1 00:01:50 - Unexpected packet: Ether addr: 00:19:4b:60:ab:4d (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0046 (PADO) PPPoE tag: type=0102 length=0014 (AC Name) data (UTF-8): E320-BRAS-LJ-DRAVLJE PPPoE tag: type=0103 length=0004 (Hos
Jan 1 00:01:50 - Unexpected packet: Ether addr: 00:19:4b:60:ab:4d (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0049 (PADO) PPPoE tag: type=0102 length=0017 (AC Name) data (UTF-8): E320-BRAS-LJ-CIGALETOVA PPPoE tag: type=0103 length=0004 (
Jan 1 00:01:50 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x427d8
Jan 1 00:01:50 - Couldn't get channel number: Transport endpoint is not connected
Jan 1 00:01:50 - Doing disconnect
Jan 1 00:01:50 - Exit.
cindy toy
Level 7
Level 7
Hi Elvis,
I noticed that you placed this question in the Europe area of our community.  I have moved this to the Small Business Wireless area of the community.  If you still have this issue, please start an online chat with one of Small Business Support Center Engineers: https://supportforums.cisco.com/community/netpro/small-business/sbproductwarranty
Cindy Toy
Cisco Small Business Support
Community Manager
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
Hi Cindy,
Thanks for respond.
I have told with my internet provider and they tell me that wouter WRVS4400N is not supported by the internet provider network.
I tell with cisco linksys distributor in Slovenia (Avtera d.o.o.) and they change the router with another supported by internet provider (WRT610N).
Elvis
