1131AG won't register with 4402 controller
dan
I am setting up a new WLAN. I've setup a 4402 controller. We have a single LAN and aren't using VLAN. The 4402 fiber port 1 is uplinked to one of our switches and I can connect via HTTPS. The controller is running sw ver 4.2.61.0
The access points we have are Cisco Aironet 1130AG series. When I connect them to my LAN via ethernet and power them up the LED light blinks; red, orange, then green and starts over. The ethernet led blinkgs green alternating with the radio LED which is blinking amber.
The AP shows up in my MS DHCP server leases. I can ping the AP using the leased IP and I get a replay, with the correct hostname. However I cannot connect via HTTP or HTTPS or Telnet. I also can't open a console session using Hyperterminal on a XP Pro box running SP2.
I added the WLAN Controller's IP address to my DNS server. I also added it to my DHCP server as server option 102 according to a doc I found on Cisco's website.
I am totally new to WLAN config, so I'm sure I've misconfigured something. But finding that something is proving frustrating.
Any help greatly appreciated.
Thank you.
Richard Atkin
Level 4
Level 4
If everything is in the same VLAN and subnet, then you don't need any special DNS or DHCP options; the AP should provision its self via a broadcasted LWAPP Discovery Message.
Is the WLC running 'Layer3' LWAPP ("Controller" tab in the GUI)?
Do you see anything in the WLC logs? The AP will most likely be referred to by MAC Address, not hostname.
HTH,
Richard
That's got it! I didn't have Layer3 enabled. Once I enabled Layer3 for LAPP and assigned the ap-manager interface an IP the AP came on line.
Thank you Richard!
