1142 Autonomous 2 VLAN connection problem IOS
BIRDHOUSE
My setup:
200 VLAN-native
100 VLAN
ssid: xxx (guest mode) for employees
ssid:yyy(guest mode)  for guests
Both have wpa2 security.
With devices : IOS,android, win10 i can connect to both SSIDs.
SSID:yyy - only win devices work.
I get IP on iphone (dhcp) - it connects but after only first age is opened in browser. It is not DNS issue - i tested with different DNS.
The same setup works on older 1240 AG series AP.
Any idea what could be wrong? I changed DTIM to 100 ...
6 Replies 6
Rasika Nayanajith
Pls attach your AP config as .txt file to have a look. Leave DTIM value as default
Rasika
! Last configuration change at 04:59:14 +0200 Sun May 12 2018
version 15.3
no service pad
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname ap_dnevna
logging rate-limit console 9
enable secret 5 $xxxxxxxx.
no aaa new-model
clock timezone +0200 2 0
no ip source-route
no ip cef
dot11 pause-time 100
dot11 syslog
dot11 vlan-name birdhouse vlan 200
dot11 vlan-name Guest vlan 100
dot11 ssid Guest
   vlan 100
   band-select
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 xxxxxxx
dot11 ssid birdhouse
   vlan 200
   band-select
   authentication open
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 0yyyyyyy
dot11 band-select parameters
   cycle-count 3
   cycle-threshold 200
   expire-supression 20
   expire-dual-band 60
   client-rssi 70
dot11 arp-cache optional
no ipv6 cef
username Cisco password 7 ccccccc
bridge irb
interface Dot11Radio0
 no ip address
 encryption vlan 200 mode ciphers aes-ccm tkip
 encryption vlan 100 mode ciphers aes-ccm tkip
 ssid Guest
 ssid birdhouse
 antenna gain 0
 mbssid
 speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 channel 2437
 station-role root
 beacon dtim-period 50
 beacon privacy guest-mode
interface Dot11Radio0.100
 encapsulation dot1Q 100
 bridge-group 100
 bridge-group 100 subscriber-loop-control
 bridge-group 100 spanning-disabled
 bridge-group 100 block-unknown-source
 no bridge-group 100 source-learning
 no bridge-group 100 unicast-flooding
interface Dot11Radio0.200
 encapsulation dot1Q 200 native
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio0.2001
interface Dot11Radio1
 no ip address
 ssid Guest
 ssid birdhouse
 antenna gain 0
 peakdetect
 dfs band 3 block
 mbssid
 speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
 channel width 40-above
 channel dfs
 station-role root
 beacon period 20
 beacon dtim-period 6
interface Dot11Radio1.100
 bridge-group 100
interface Dot11Radio1.200
 bridge-group 1
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0.100
 bridge-group 100
interface GigabitEthernet0.200
 bridge-group 1
interface GigabitEthernet0.2001
interface BVI1
 mac-address cccc.cccc.cccc
 ip address 192.168.200.241 255.255.255.0
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
sntp server 2.europe.pool.ntp.org
sntp broadcast client
end
Try below modifications & see if it helps.(most of them help you to bring configs to default values which is recommended)
no dot11 arp-cache
int d0
no beacon privacy guest-mode
channel least-congested
speed  basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
beacon period 100
int d1
beacon period 100
beacon dtim-period 2
Rasika
*** Pls rate all useful responses ***
No difference.
SSID 1 working SSID 2 gets IP DHCP but not connecting to internet...
It's look like vlan 200 config issue (DNS/NAT).
If you getting an IP to the client, can you ping 8.8.8.8 ?
If you configure vlan 200 switch port & connect your laptop using a wire, will that device get internet access ?
Rasika
i reset to default and put the same settings as written above.
now it is working
