1242AG Fault Light
iain.mccutcheon
I have a number of 1242AG's installed in a factory, and one of which will not operate properly, as it is on a girder about 20m high, I cannot see which LED, but either the ethernet or radio LED is red, and the status LED is green. This occurs about halfway through the boot process.
Cisco network assistant can see the device, but it cannot be pinged and cannot be telnet-ed to!
HELP!
Thanks.
6 Replies 6
Scott Fella
Take a look at this link... hope it helps:
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_7_JA/configuration/guide/s37trb.html#wp1065824
Is this an autonomous AP of LAP?
-Scott
Autonomous AP.
Thanks for the link, I think I will be able to manage now. I could not find that page no matter how much I searched!
Thanks.
Yeah I got it, just meant the link you sent me was the one i needed but could not find myself!
Thanks again.
Ah. Well hopefully you get it working.
-Scott
Should do! Thanks again.
