1800W - typical wireless config example
alter-sol
Community Member
I have a 1800W router it has a vpn tunnel built back to another 1800 router the 1800W router has one vlan built with dhcp enabled. I'd like to have the wireless dot11 push out the same dhcp as the vlan with wep enabled. have been tinkering but can't quit get it to work, should be easy yet i can't get it. does anyone have a smaple config?
thanks in advance..
Scott Fella
Take a look at this post:
https://supportforums.cisco.com/thread/2048192
http://www.cisco.com/en/US/products/ps5853/prod_configuration_examples_list.html
http://www.techcity.cgngroup.com/2010/07/configure-cisco-1811w-with-dual-wireless-access/
Scott Fella
Sent from my iPhone
-Scott
