1811 wireless config
networking
I am trying to configure my dot11radio0 interface with an ssid of test on an 1811 router. Has anyone done this before? Here is my current config.
interface Dot11Radio0
no ip address
ssid test
speed basic-54.0
channel 2437
beacon period 20
beacon dtim-period 1
station-role root
r-simpson
Level 3
Level 3
Yes this configuration is right.But using only 54.o mbps allows the connection only at 54 Mbps.In case if the data rates drops on the clients due to interference or weak signal strength clients would be dropped.Try configuring lower basic data rates.
