08-08-2013 12:22 PM - edited 07-04-2021 12:37 AM
Hello All,
I have a 2504 WLC connected to my internal LAN and internal SSID's working great.
What I would like to do is setup a guest SSID and have it use a physicially seperate interenet connection (DSL) I am using a PIX 501
for my DSL and that works great, but then I connect the PIX to a port on the WLC and assisgn a Guest SSID to it, I am unable to get an IP.
1. Can this setup work ?
2. Currently my management interface is untagged, can I have multiple untagged interfaces ?
3. Should I use the WLC as a DHCP server or the PIX ?
Any help would be greatly appreciated.
Solved! Go to Solution.
08-09-2013 11:27 AM
Why not connect the dsl to the same switch and use vlans. That might be easier to get working. You don't have to have a layer 3 interface. You would just create a vlan on the switch just for the dsl and the one port off the WLC.
08-08-2013 12:26 PM
you can only have one untagged vlan per port.
So you could use, say port 4, and have that untagged to your FW. But if the FW is doing the DHCP, you'll want to disable dhcp proxy on the WLC
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
08-08-2013 12:37 PM
Hey Steve,
Thanks for your reply.
These are physicially connected to seperate ports. I am hoping to use the WLC as the DHCP server for the Guest WLAN.
08-08-2013 01:26 PM
You should be able to use the WLC as the server then.
HTH,
Steve
08-09-2013 09:36 AM
I must be missing some DHCP options, as I cannot get an IP when connecting wo my WLAN. I get L2 connectivity just no IP. How can I debug this ?
Cheers
08-09-2013 10:14 AM
Post your show run-config or the interface configuration.
08-09-2013 10:29 AM
Here are my pics..
08-09-2013 11:25 AM
That doesn't have enough info to determine anything.
08-09-2013 11:27 AM
08-09-2013 12:06 PM
I can use a Layer 2 switch with Vlans but not sure how that will help ?
08-09-2013 12:10 PM
Trunk the ports and only allow the vlan for that port. This way you can tag the manager and the dsl vlan.
08-09-2013 12:17 PM
Thanks Scott,
I will give that a shot. Appreciate your feedback.
08-10-2013 06:36 AM
Let us know if that worked.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
08-11-2013 08:21 AM
Dear
It is very easy. all the things you have to do is to play with VLAN. i am attaching one diagram which might help you in understanding vlan allocation.
08-12-2013 01:04 PM
Thanks Guys, worked flawlessly.
Cheers
