3850 controller ACL working with ISE
Hi all
I was wondering if anyone can point me to the right direction. I was setting up BYOD access with ISE and Legacy controllers as follows:
- create rule on ISE with Redirect / Airspace ACL
- once that rule is hit ISE would send ACL name that needs to be applied on the controller (i.e. NSP-IOS )
- controller would need to have the same ACL created locally with matching name
- there are certain rules on old controllers allowing inbound / outbound traffic + denying traffic to be redirected
now I want to use the same principle with 3850 controller.
question is -> where do I configure this ACL, globally or under WLAN.... Also, what about direction - inbound / outbound that used to be the case with legacy controllers?
Saurav Lodh
Level 11
Level 11
The ACl should be under the WLAN
