4400 WLAN controller
rvolkman1
Community Member
I'd like to add a 4402 controller to manage a number of 1231 APs converted to LWAPP. I'd like to use Web authentication against a Win2k3 AD database. Is there a Cisco security appliance or security application that should be placed in between the 4400 and the AD server?
Thanks - RV
ankbhasi
Hi RV,
I believe you can use CISCO ACS server.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/index.htm
Ankur
wwiedemann
Community Member
The ACS Solution Engine (appliance) is what we have here. It can use an agent on a member server for AD authentication. In addition, it is our RADIUS and TACACS+ server for our router and switch management access as well as our VPN authenticator for our firewalls. It works really well, but is a little quirky to configure.
