4402 two controller with 16 access pooint need help to config fallback mode
We have 4402 two controller with 16 access pooint, I need to configure redundancy for both controller, we need two network in wirless [ data & voice; SSID - WLData, SSID - WLVoice 172.16.124.0, 172.16.125.0], I had followed the below URL:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008064a294.shtml
But the fallback is not working, please suggest me what are key point to be noted while configuring fallback.
Leo Laohoo
If your firmware is 4.X then this document is sufficient.  If you are using 5.X or 6.X firmware then go through the WLC Configuration Guide.  Can you elaborate when you said "need to configure redundancy for both controller"?  Do you want your AP to join the 2nd controller in case the 1st controller goes off line?
yes we want  AP to join the 2nd controller in case the 1st controller goes off line?, firmware is 6.x, when I try both controller in same network and with same ssid for both the controller, our access point get disconnected. Please light me what should be the issuse for access point disconecction
