Hi all,
Has anyone managed to get the new HA feature working properly with LAG enabled? Without LAG, I can simulate a failure of the Primary WLC and the Secondary kicks in as active as expected; however, when LAG is enabled the units go active/active and there is no way to get the setup to recover no matter how many times I reboot either WLC as they don't negotiate the correct state on bootup because they can't see each other, even though all links have been reinstated.
Also, why is there a limitation that says I have to directly connect the redundancy ports on each unit? I would prefer to have the WLCs on different sites, connected by a L2 link. It seems like a half-finished feature if you can't split them up.
Thanks in advance,
Jason
