5508 Wireless Lan Controller
Alvina Paquin
Community Member
I have been monitoring the alarm summary but have been off couple days and i see one of my controllers is down.  Getting  critical level security and message is port is down on the controller, condition link down.  The other issue is config difference found between NCS and Contoller, I tried getting them to sync together but still getting the same message.
Amjad Abdullah
Alvina:
can you login to the controller directly? open the GUI (or CLI) and login?
Try to audit the WLC configuration and see what are the exact config that differs.
Amjad
Rating useful replies is more useful than saying "Thank you"
