5760 Web Auth
Richard Bidmead
Community Member
Hi all,
I have come across a potential issue regarding the web auth and http server on the 5760. We are using one of these as a guest anchor controller with web auth. It initially worked fine with a small scale user count (20-30), however, on scaling up we find that the local web server seems to stop responding and leave a lot of clients on a WEBAUTH_PEND state. Looking through configuration options it appears that the http server has a limit of 50 concurrent connections. Is this limit going to hold us back? Or is there some other limitation somewhere I haven't seen?
WLC(config)#ip http max-connections ?
  <1-50>  Maximum number of concurrent http server connections
Richard.
0 Replies 0
