10-12-2009 08:02 AM - edited 07-03-2021 06:08 PM
Picked up a few 7920's second hand (yes, there old, but they are for my lab) - needless to say, the last person to have them locked them down pretty tight. It seems they are set to "Disabled" (as in, past restricted) - basically I can not change any settings on the handset itself.
The handset is stuck on "authenticating with AP" , but since I don't know the SSID its looking for, or even the key- I'm kind of stuck (and, I did try w/ the SSID as cisco, and open auth with no luck)
The reset procedure (Menu -> *## -> Send ) does not work, and I can not reset via the phone lock / password reset either
I do have the USB base station and the proper software- but of course, since I can not enable USB mode, I can't get any system to acknowledge that a device even exists.
Of course, since the phone is EOL, I can't get a SmartNet contract any more, to top things off, that is!
So, was wondering if anyone had any ideas - little desperate here, don't want the phones to go to waste!
Thanks!
CJ
10-12-2009 04:54 PM
Take a look at the following thread.
Other than that, can't help much here.
10-12-2009 05:09 PM
Thanks - I did read that previously, alas it was no help, since I can not lock the phone.
