7925G unable to connect to wireless
peter.warwick
Cisco WLC 5508 showing the following error messages.
*apfMsConnTask_5: Dec 01 10:29:00.415: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:205 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 30:f7:0d:4d:6e:11.
*apfMsConnTask_5: Dec 01 10:28:58.774: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:205 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 30:f7:0d:4d:6e:11.
*apfMsConnTask_6: Dec 01 10:28:58.534: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:205 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 30:f7:0d:4d:6e:11.
*DHCP Client Task: Dec 01 10:24:26.094: #DHCP-3-BIND_SRPORT_ERR: dhcp_support.c:373 Binding service port failed.
*apfMsConnTask_6: Dec 01 10:18:23.690: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:205 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 30:f7:0d:4d:6e:11.
*apfMsConnTask_5: Dec 01 10:18:23.254: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:205 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 30:f7:0d:4d:6e:11.
*apfMsConnTask_4: Dec 01 10:18:22.840: #APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:205 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 30:f7:0d:4d:6e:11.
Does anyone have any ideas?
Scott Fella
Take a look at what data rates you have supported and what you sent as mandatory. Also look at the client that the error is pointing to.
-Scott
-Scott
Leo Laohoo
The default data rates for the 7925G is 12 Mbps.
So what data rates are enabled Globally (and/or RF Profiles)?
