A report showing Wireless Clients using WPA2
ppellettiere
I am looking for a way I can search the WCS to find Clients
using WPA2. Is there a way to do this. I don't see it in any reports.
Stephen Rodriguez
if you're not running mixed WPA2/WPA WLAN, you could pull the WLAN report, then parse out the non WPA2...
Cheers,
Steve
If  this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
jc378
You should have a look in the "Client Sessions" report of the Report Launch Pad.  You can customize the report to include "Policy Type" and "Encryption Cipher" which will give you both WPA1/2 and TKIP/AES details of associated clients.
