Access point is not shown in WLC
rakesh4
My problem is Access point is not showing in Cisco Wireless controller. From Cisco Wireless Controller. I am pinging to access point IP address &my router IP Access point getting the IP also. I am creating the SSID In Cisco Wireless controller. Below is the my configuration
7 Accepted Solutions
Sandeep Choudhary
also paste the output of these commands:
sh sysinfo from wlc
sh version form AP
Dont forget to rate helpful posts
Mere bhai..thats is not complete info what we require.
Paste the output of this comamnd form AP console: sh version
and also paste the complete bootup process from AP console.
which AP model you have ?
set corerct time on WLC and try again.
Command > Set time from WLC GUI
AP has the wrong Regulatory Domain.
Leo is spot on..
you have a regulatrory mismatch...
For india you need to buy the corerct AP with right Indian domain.
You have two ways:
Did you correct the date/time on WLC ?
Either chnage AP model or chnage the country code on WLC (Which i dont recommand and its againest the law).
So better you should change AP otherwise it will join but only 2.4 GHz radios will be enabled.
Glad It worked.
Thanks for rating
15 Replies 15
Leo Laohoo
Console into the AP and reboot the AP.
Post the entire boot-up process.
Sandeep Choudhary
sh sysinfo from wlc
sh version form AP
I am already post the Wireless controller ,switch details.please check once
I am post details below
But I am forget the username and password
In boot up process it shows the IP address.
Not Getting Friend
help me please
Leo is spot on..
previous days it is working fine,but now it is not working and why friends
You have two ways:
Thanks Leo and Sandeep. It working after changing time on WLC but as you siad only 2.4 Ghz is UP.
Thanks again
Glad It worked.
Thanks for rating
where should we copy those outputs?
