Access Point not connecting with 1G ethernet
Babak KHorshid
HI everyone.
I just noticed this. I have different series of AP , 1142 , 1252 , 3500 , 3700. it is happening on any series. if I set the duplex and speed to Auto some of my AP are connecting with 100mb not 1Gps.
if I set duplex to full and speed to 1000 then the AP shows not connected on the switch and the AP it self is blinking like a Christmas tree!
I have different series I switches as well and it happening on all of them. they are Gig
this is the 3850 series out put of the interface
 description Class7.1A
 switchport access vlan 10
 switchport mode access
 spanning-tree portfast
end
speed and duplex is auto and it is connected with 100mb!
any comment appreciated
10 Replies 10
Rasika Nayanajith
Usually AP gig port should go to 1Gbps full-duplex. You should not set speed/duplex manually & leaving them auto/auto is the recommended practice.
Can you run the below on few of your switches & see Full-duplex 100Mbps negotiation occur only for AP connected switch ports.
show interfaces status | in a-full a-100 10
I would check the IOS version of these switches as well.
Rasika
**** Pls rate all useful responses ****
Hi my friend Manannalage
the switch ios is 03.03.00.SE
i have other APs (same series) running on 1G on the same switch
here is the proof :)
can it be the cable quality dropping from 1000 to 100? I'm going to un-mount the AP  from the wall and connect it directly to the switch to see what will happen
Gi1/0/23                     connected    trunk      a-full a-1000 10/100/1000Ba
seTX
Gi1/0/24                     connected    trunk      a-full a-1000 10/100/1000Ba
seTX
Gi2/0/1   Class8.1B          connected    10         a-full a-1000 10/100/1000Ba
seTX
Gi2/0/3   AP                 connected    10         a-full a-1000 10/100/1000Ba
seTX
Gi2/0/10  Class8.1A          connected    10         a-full a-1000 10/100/1000Ba
seTX
Gi2/0/11  Class8.3           connected    10         a-full a-1000 10/100/1000Ba
seTX
Gi2/0/12  AP                 connected    10         a-full a-1000 10/100/1000Ba
seTX
Gi2/0/15  Class8.2           connected    10         a-full a-1000 10/100/1000Ba
seTX
Gi2/0/16  AP                 connected    10         a-full a-1000 10/100/1000Ba
seTX
Gi2/0/18  AP                 connected    10         a-full a-1000 10/100/1000Ba
seTX
Gi2/0/21  AP                 connected    10         a-full a-1000 10/100/1000Ba
seTX
Gi2/0/22  AP                 connected    10         a-full a-1000 10/100/1000Ba
seTX
Gi2/0/23                     connected    trunk      a-full a-1000 10/100/1000Ba
seTX
Gi2/0/24                     connected    trunk      a-full a-1000 10/100/1000Ba
By the way , now I have a nightmare every night because of you :) im like oh you are not updating your website any more :) thanks for the us full stuff you post there.
"By the way , now I have a nightmare every night because of you :) im like oh you are not updating your website any more :) thanks for the us full stuff you post there"
Hopefully things will calm down by end of the year (once I complete my CWNP studies). I have done a basic debug client post per your request.
Enjoy it
Rasika
Thanks. you are amazing. I wanted to say thank you on the post but you closed the comment section in the website . Once more thank you
No, I have't block comment section in my blog :)
Try with different browser & see.(let me know in which platform you have issue to put a comment)
I will do PSK & 802.1X for your benefit.
Rasika
Babak KHorshid
HI. for any one later use on this topic.
I connected the AP directly to the switch and got 1G speed. it was the freaking patch lead.
Good to see you figured it out quickly. :)
Hi I have the same problem, but it is not a patch cable issue. It is something with AP
I had the same situation, and here also the culprit was the patch cord.
I'm clear, this is an old thread, but this saved my bacon.  I'm getting ready to replace these next year, but had to add 1 more for a new project.  It was connecting 100mbps and it was driving me insane!  It was the patch cord.  Thanks!
