ACS Not installing renewed SSL Certificate for PEAP/EAP-TLS?
matt.orlando
We recently renewed our SSL certificate through RapidSSL. While attempting to install the new certificate into ACS, I was given the prompt to showing the updated dates, confirmed and installed the new certificate, deleting the old. I restarted ACS, as required, but when trying to enable PEAP or EAP-TLS, I am getting the error "Failed to initialize PEAP or EAP-TLS authentication protocol because ACS certificate is not installed."
The worst part, is that I when I tried to reinstall the old certificate, I am now getting the same problem.
Any suggestions?
Scott Fella
Matt,
How did you perform the CSR.... did you use ACS or OpenSSL? Also, did you verify that the certificate is in the trusted personal folder on the server?
Scott
-Scott
