ACS solution engine to Join Domain
c.ong
Level 3
Level 3
Hi Sir,
I would like to know how can I join a Cisco Secure ACS solution engine to Domain? The only way for me to access the ACS solution engine is via console. I know from the fact that in order to run PEAP with Windows AD, the ACS has to be a member server of the Domain COntroller. I plan to run PEAP MS-CHAPv2 for my wireless deployment and Windows AD as the external database and ACS solution engine as the RADIUS server.Please advise.
Thank you.
Delon
Jagdeep Gambhir
Level 11
Level 11
Delon,
You need to install remote agent on the member server. Using remote agent appliance will be able to talk to AD
ACS----> Remote agent----->AD
Remote Agent,
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.0/installation/guide/remote_agent/rawi.html
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.0/user/guide/n.html#wp372828
Hope that helps !
~JG
