ACS with EAP-TLS
Roger Alderman
Level 5
Level 5
Hi All
We have just setup a wireless network with an ACS running EAP-TLS with Microsoft AD.
ACS is version 4.2.0.124
ACS Remote Agent is running on Win Server 2003 Enterprise R2 (32 bit).
Initially we saw failures in the ACS logs stating 'External DB is not Operational'.
We resolved it by upgrading the ACS Remote Agent to version 4.2.1.15
Does anyone know if ACS Remote Agent 4.2.0.124 is supported on Win 2003 Enterprise R2?
Thanks.
The latest 4.2.0.124 RA (I think that's 4.2.0.124.15) supports Windows Server 2008 (Enterprise 32-bit), so I would GUESS that it supports 2003 R2.  However, I couldn't find anything in the release notes (it just mentions 2003).
If the 4.2.1.15 is working, is there a need to revert back to 4.2.0.124?
