ACS5 : Invalid EAP payload dropped
ccr_cisco
Level 2
Level 2
Moving the authentication of our Wifi from an ACS express on WLSE to an ACS5.0 prevent any user to connect. the error message on the ACS 5 is :
101 Invalid EAP payload dropped.
Internal error, possibly in the supplicant: Could not validate an EAP payload. Silently dropping it.
Supplicant : IBM Access connection
AP : Cisco 1130
Authentication EAP/PEAP/Ms-Chapv2
I try changing doing the same connection with the Microsoft supplicant it works !
Seems that the problem occurs between IBM AccessConnection and ACS5
Is it a known problem ? is there some solution ?
0 Replies 0
